Hi I have just purchased a 2nd hand DV. First of it made an immediate and noticeable difference, extending both the top end and bottom end. I tried the USB out first, but found using an Urendu as a NAA provided the best sound.
Hi Mark
Is it possible to SSH into the vortexbox and update the distro or are there custom kernels?
Is it possible to load the Sonicorbiter OS onto it.
While it is technically possible to update the software, the DV board wouldn’t give the experience we would like with the current software suite.
There are a couple of options, continue to use and enjoy the DV as is, or hardware upgrade to DX3. If you wish to go down the hardware route please fill in the form here Upgrades - Antipodes Audio
