We use both of the Jorma AES and Ethernet here.
The Jorma Ethernet is the best we have encountered to date.
Good day, colleagues, replacing the Ethernet cable on the CX is a big problem! I turned off the device, replaced the Ethernet cable and voila - the antipode is no longer detected in the network! After changing the Ethernet cable, do I need to re-set up the initial settings, even if the home network has not changed?
