Turns out that listening to the CX / EX via Squeeze will occasionally lead to a split second disruption during music playback. This can happen randomly for DSD64 and DSD128 tracks. I have not tried on full length albums in other formats yet. I have none of these problems when I use my SOtM SMS 200 streamer before the EX. The CX goes into the 1Gbps and EX into the 100Mbps ports on the Melco switch.
Oladra upgraded cx+ex stack here and using squeezelite … nvr had mentioned disruption before or after oladra upgrade in last 3-4 yrs thru various ams versions till latest.
Interesting setup which I do not understand why isn’t cx server to melco switch for upstream clean up and ex player simply directly to cx ?
Connecting the EX to the CX via Direct Stream is exactly that direct, rather than going thru your home network/switches, etc, this is the preferred connection.
If you are experiencing disruption, I would try the Direct Stream
Just to add … Antipodes connectivity between the cx and ex is robust. I do have an uptone etheregen switch between them as well as another etheregen before the cx but nvr had any disruption … dsd or otherwise via Squeezelite . Cheers.
