Hello and sorry this is a long two-part situation…
Coming from a Bryston BDP-2, got a pre-owned EX, and have storage set up, and files transferred to it to a new Samsung EVO 2TB. Software version AMSv4.31
The way I like to listen is to play the entire library on shuffle. That way I “re-discover” the music I own. (could do this with the Bryston, using MPD, and controlled with third party iPad apps Rigelian and Soundirok. Plus I seem to be the last person on the planet to not have a Roon subscription.)
Purchased Mconnect Player HD app because it has the ability to do the above. However, no matter what combination of settings I try in the Solution control pane, Mconnect won’t see the EX as a player. It does see the library /music files. Rigelian can’t see the EX either.
Preset: have tried both MPD options
Player Settings: EX = MPD
Server Settings: EX have tried Minimserver and MiniDLNA
Have tried all manner of restarts and refreshes.
So not sure what is wrong, or what step I’m missing?
Part 2:
Decided to try Squeeze preset, with Squeeze as player and server, and purchased iPeng app to control the playback.
Now I have music. And I think I figured out a workaround in the settings to play the library on shuffle.
However, if I power down the EX, it’s not recognized when powered on again. I’ve read in other posts about the solution of toggling between Squeeze and Roon in the preset, and this does set things right.
But having to do Squeeze -Roon -Squeeze in the Solution control panel every time is a pain in the neck, and doesn’t seem acceptable.
So is there a software solution in the works?
OR: is it ok to leave the EX powered on all the time? Does it need to be powered down?
Thanks for any insight…
