Installed 3.12 on my CX without a hitch, working perfectly.
Hi @MarkCole , I had been trying to get Squeeze in 3.12 to play 705/768 files and was not using C-3PO because you said it was not needed for the fix. It now appears that 3.12 merely downgrades the loaded version of Squeezelite to an older version and that C-3PO plugin works again. Are you still working on the fix which doesnāt require C-3PO to that we can again take advantage of later version of Squeezelite as they are released?
Of course
Hi @MarkCole I have spent quite a bit of time with your suggested cache issue and in the process tried different browsers on different machines and also cleared their caches. All with no success. Then this morning I tried a different tack and on the Antipodes Server dashboard Squeeze settings cog I reinstalled Squeeze and Cleared the Database. That has cured the display issue with material.
I agree that what you were suggesting made sense but for whatever reason it was not working.
Thanks, Nick
Excellent, at least we have a temporary fix. Thanks.
So if weāre not using PGGB files, not much point in 3.12?
@Tintin
Always a point
v3.12
Squeeze Remote Control
Some minor updates
Squeeze Player
A critical fix for a small number of users experiencing problems with Squeeze Server losing Squeeze Player. And a critical fix for users wanting to play very high bit-rate files.
Security
Some minor security enhancements
Just finished update all good , but at the end it sayās to log back in but I have never had a user name or password so I am locked out to play music , just need some help.
Can you go back to my antipodes page? Iāve seen that page before, I think you can get around it. Bit vague butā¦
Hi Tintin
Thanks , just went back through the pages , then skipped the up date restarted and reset . All good thanks.
Itās never a good idea to skip an update
Hi Mark
I did the update but when I went back into the start page after updating it would not let me go any further unless I went back through the update again , but by clicking not to update I was able to go to the front page.
Minor issue with 3.12. Material doesnāt remember that Iāve set it to dark mode. Whenever itās launched it goes back to light.
3.11 was the same for me, so may not be related to 3.12ā¦
Thanks for the feedback
I have a problem with 3.12 material as it doesnt remember that I have set - donāt stop the music - to disable . When I launched squeeze it goes back to Songmix .
@rowberry1
Thankyou for your feedback, I have passed this on to our development team
What exactly is material?
Material is the web interface player for Squeeze
You asked me previously if Iād used it, but I didnāt even know such a thing existed, much less how to access it. I still donāt & perhaps you could further enlighten me? My K50 arrived with only a single A4 sized piece of paper with pretty much nothing by way of instructions on it. Most of the guides are still under construction & so where can I access information on this?
