Could you please help me in installation of my system? I use Antipodes CX as a server and Lyngdorf TDAI-1120 as a player. What will be the better to use as Audio Output - Special DAC or None? Thanks!
What is the software version of the CX?
Basically, you set the CX to Server Only and have Roon Server enabled.
You do not have any Audio Output selected as you aren’t using any, set to NONE
Thanks for your response! I have software version - AMS v5.0.0
You may wish to book a support session to bring you up to v5.0.1
Thank you! I have booked a support session!
