Antipodes EX with different port config
Hi All,
I found 2 Antipodes EX for sale in my area. I noticed a different lay out on the connections on the back of the EX.
One EX looks to 4 USB ports under the Analog out connectors. The hdmi ports on either side of the network ports.
The other has only 2 usb ports, not including the 2.0 audio usb ports. Also the hdmi ports are side by side.
Can you tell from the back of either of these EX models that maybe one is newer than the other ?
Perhaps the 1st model with many usb ports is newer ?
Any background on this, would be greatly appreciated.
Cheers
How many SSD slots does it have? This is the easiest way to tell.
Two slots - Early model
One Slot - Late model
There were a number of EX variations.
Ok, I do notice the one slot and 2 slot versions. Any differences internally ? If you had a choice would either version differ besides the storage slots and USB ports ? Sonic differences… etc…
Thanks for any info you can provide.
Sonically the units are all very similar.
I would opt for a later model single SSD slot version, purely as it’s newer.
Purchased my EX in Aug 2019 so first UK batch and had single SSD slot.
