For some reason on K30 roon will no longer see roon player . Can access other roon enabled devices just not the K 30 player. Tried full system reboot etc and checked settings in Antipodes app but cant see what th e issue is.
Squeeze server cannot be running if you want to use Roon with Squeeze player.
The preset you selected on the Solution dashboard is for Squeeze only. Change this to Roon (auto) or Squeeze player with Roon Server (auto). If you select the latter, be sure to confirm that Squeeze box streaming is enabled in Roon.
Thanks Kenny
Have no idea how that happened - any way working fine now
Much appreciated
Happy to hear that it’s working fine now!
