Antipodes oladra clock vs msb cascade clock
hi
which clock is in the oladra and is it better
than the cascade dac.
thank you
Hi ofer,
maybe you would want to check this article in the following link if you haven’t
“The Best Connection To Your DAC”
I’m a reference DD + DAC user and Cascade definitely have better Digital Director which would re-clock / buffer all incoming signal.
If you’re using Oladra G4 then the output doesn’t matter that much as all signals are re-clocked before entering Cascade DD and DD will get the signals re-clocked again before sending it into Cascade DAC.
For now I’m settled with I2S and I’m very happy but you will need to test with your ears!
