Hi i think i messed up a setting somewhere or other - is there any way to reset or start from fresh with lms/squeeze on an oladra. I just get white noise (
Generally when playing with C3P0 can give white noise, this can be disabled in both Server and Player Plugins
thx Mark, i get white noise on both 44.1 and hi res tracks tracks. i turned C3PO off on player, no difference, i dont see C3PO anywhere in LMS server settings? my ‘solution’ is squeeze playing to usb using the oladra player from LMS. any ideas or is there an easy way to reset LMS to Oladra factory settings?
The isnt a factory reset, you will need to book a remote session for the team to re-install.
