Has anyone tried WAV64 on thier antipodes?
W64 is different from a WAV file that has been converted with something like PGGB.
The WAV format is limited to files that are less than 4 GiB, because of its use of a 32-bit unsigned integer to record the file size in the header. Although this is equivalent to about 6.8 hours of CD-quality audio at 44.1 kHz, 16-bit stereo, it is sometimes necessary to exceed this limit, especially when greater sampling rates, bit resolutions or channel count are required. The W64 format was therefore created for use in Sound Forge. Its 64-bit file size field in the header allows for much longer recording times.
I tested it, doesn’t work
