Greetings,
Long term Antipodes enthusiast but new to the forum.
My current digital source set-up is Antipodes CX>EX>USB out>Weiss DAC204>preamp>amp>speakers.
I use Roon for both streaming music (Tidal, Qobuzz) and of course playback of my local files on the ssd in the CX.
I’m contemplating replacing the Weiss DAC with the purchase of a used dcs Bartok streamer/DAC.
The main issue: I’m uncertain how to connect the Antipodes gear to the dcs Bartok streaming DAC.
Perusing the audiophile forums I find the following:
CX>EX>USB out>dcs Bartok.
If I understand this method correctly it would imply that the EX is the endpoint and that I would not get some of the “benefits” (roon ready, MQA) of the Bartok?
- CX>Network direct out>Bartok.
My layperson understanding is that the CX would be the Roon core/Server of the local files and the Bartok would handle all streamed sources like Tidal, Qobuzz.
This method would completely remove the EX from the playback chain and is my preferred method (if it works!) as it simplifies my system.
In addition it would allow me to repurpose the EX as a standalone server/renderer in an infrequently visited vacation home paired with some KEF LS50W speakers for non-critical listening.
Has anyone tried this or is able to confirm this method will work?
- CX<>Network switch<>dcs Bartok.
A web forum said that one MUST use a Network Switch between the CX & Bartok in order to have the Bartok handle the streamed music. If I understood their argument it was that without a network switch the Bartok has no way to access the internet for streamed music.
For purposes of system simplicity (one less component/power cord) I’d prefer not to have to use a network switch but can do so if its necessary.
Any thoughts or comments are gladly welcomed.
