Digital output not found
I have a K50 (probably gen 1) and I use roon for transport/player. I recently bought a second dac (mscalar + Hugo tt2) which I hope to connect to k50’s SPDIF output connection, however, after all the wiring are done, I check my antipodes solution panel for “digital output”, this option never appear. I even disconnected my primary dac which uses USB output to test if the “digital output” work, but no luck. I wonder if there is a problem with my unit. Any advice is welcome.
P.s. in case you are wondering, my bnc cable is 75ohm.
Thanks in advance.
Kevin
Hi there please book a support session with the team so they can check the configuratio:
