Hi Harry,
Well it took an absolute eternity to run in, but after it had there was definitely no parting with it. It’s a terrific cable, but I’d absolutely hate to run in another. Even leaving Roon Radio feeding my DAC 24/7 it still took weeks before it settled fully. Even when I thought it finally had (which was early January), it transpired that there were still a couple of small surprises in store.
I did some brief experimentation with the articulation control, once the goal posts finally stopped moving, but to my ears & on my system the standard/middle setting sounds the most natural & I haven’t touched it since. Even then I only really tried it out of curiosity.
It was expensive, but made a huge improvement over the Audioquest Wild AES/EBU & Live Cable Xtreme USB cables I previously owned (particularly over the Wild) & it’s totally exceeded expectations.
Soundstage by comparison to my former options increased markedly in depth & by a couple of feet or so, but width slightly increased too, although to a lesser degree. There isn’t one area of presentation that appears to have taken a backward step compared to either of my previous cable options & there have been gains in multiple areas (dependant on which of my previous cables it’s compared to). Far more, against the Wild.
It was strange with my former Wild AES/EBU. It was a cable I’d owned & used for a few years & it worked really well between my old transport & previous DAC (both MBL), but between my K50 & N31 it just never really gelled & I didn’t like it. I’d fully expected the Wild to be the better out of my former cables, but my old Live Cable Xtreme USB was easily preferable & by no small margin.
They’ve both been surpassed with the MIT Oracle AES/EBU as the performance of that is on a different & greatly enhanced level. However, it does rather illustrate that you can’t just assume one connection type will be better over the other, even when using cables you’ve long been familiar with & when both have previously rendered very satisfactory results. The Live Cable Xtreme USB continued to perform at a high level but the Wild AES/EBU really didn’t sound that great & yet I know it’s not a bad cable. It should have by all rights sounded better, but in this particular case, the reality was rather different.
The MA-X was my last purchase of any significance & I’m not actively looking to make any further alterations whatsoever. I’m at that happy place where pretty much all I do with my system is listen to music. The MIT cable played a reasonably sizeable part in that & so despite the slightly steep ticket price, I personally feel it was worth every penny.
