DSD Playback in Roon - no sound - K22
Hello,
I can no longer hear any sound when playing Roon. I can see it’s playing the file but there is no sound - I switch back to a normal PCM file and no issues. Only occurs with DSD files. How do I fix this issue? Or is it Roon related? All settings are default for DSD (DOP).
Thank you!
Try turning off the EQ. Also check if DSD256 is supported by the interface and hardware you selected.
edit: if you are running Roon Core on your K22, the CPU isn’t powerful enough for DSP.
