As per the title I own a DX and have a disc that won't eject. Have tried the device turn off / on, power etc and no luck. Is there a trick I don't know about? The DX is otherwise running fine. TIA, Greg
There is a manual release inside the unit, if it isnt ejecting, it may need replacing, please reach out to support@antipodes.audio if required
Hi Mark, Many thanks for your reply. I appreciate it. Will fire off an email to support as advised. Thanks again.
