Gen 5 upgrade 2026
I own a four-year-old Antipodes K41 currently running AMSv5.0.1. I use it solely as a Roon Core.
I do not want to upgrade the K41 to G5. I will probably buy a new Antipodes server sometime in the future, but not yet.
Question 1: Will I stick with AMSv5.0.1, or will there still be updates?
Question 2: Can I expect to use the K41 as a Roon Core for years to come without a G5 upgrade?
Thanks for your reply, Mark!
@Edwin
Any upgrade is totally up to the owner, what we try and do is offer everyone the opportunity to keep pace with our latest developments and technology
There will be updates, likely 3rd quarter
Sure, but we have no control over what Roon may do in the future, and what may be required hardware-wise to support the ever evolving landscape of software development, what I can say is we will continue to support all our products as we do now, within the capabilities of the hardware
Hi Mark Cole, I know this question is a bit premature, but I’m also currently undergoing a digital transformation and want to switch back to USB. I really like the new Kala 50 G5 and its current “less is more” concept. One USB port, and that’s it. The option to add AES/EBU is certainly interesting for many. I also like the SSD storage options. My library is manageable, so a 4TB internal solution is sufficient. I have a few questions about this. I currently own a K50G3. Will the G5 generation upgrade remove all synchronous digital outputs except USB and the optional additional synchronous digital output (if desired)? I assume the G3 isn’t designed to be upgraded to the G5, right? Would it therefore make more sense for me to sell my G3 to someone who’s upgrading to the G5 and still has all the digital outputs available? So that I can plan accordingly, could you please give me a price for the Kala50 G5? An approximate price? USB only, 4 TB internal SSD library.
Thanks Mark. What upgrades will be available for a K40?
Maybe 3 new models? :slight_smile:
Its seems the Oladra Core is purpose built computer, like JCAT did, and Kala will continue the traditional model of finding the best sounding hardware and optimising AMS and PSU for best synergy.
And a new switch! Touche to JCAT, Innuos and Taiko!
I have two questions:
I have a K50 G2 and I’m interested to upgrade it to G5, is this possible?
I’m a fan of NOS dacs with tube outputs, these are unfortunately mostly limited to coaxial and AES/ebu.
Will these optional output boards will be available for the K50 users or is this strictly to Oladra users?
Hi Mark
I’ve a K40 but I don’t see that on the list as available to upgrade, does that mean I’ve no upgrade option? :anguished:
Hi Celts88,
Your model should be eligible for the Gen5 upgrade - please see below:
On your page of previous models, you have a note on the S30 and S60 saying they will be eligible for the Gen 5 upgrade.
True or a mistake?
True, if you want it, we can do it
Hi Andreas
Whereabouts did you find that info, I couldn’t find it on the Antipodes website?
Hi Celts88,
Antipodes Audio website (https://antipodes.audio) —> at the bottom, click on Legacy (Antipodes Music Servers/Streamers Past Models )—> select your model…
Cheers and Happy Easter!!!
Thanks so much for that Andreas much appreciated :grinning:
Hope you had a good Easter break too :+1:
I like the idea that my „new“ K 41 G 4 (2024) will go on a long journey to New Zealand to get a G5 update and come back with even better sound quality .
I own a La Rosita streamer/DAC and the device has travelled to Grasse in southern France to its developer Dan Bellity maybe 4—5 times. It started with AirPlay as an Omega and is now a GammaHD with a sole LAN input and the latest updates to the DAC and the output stage. After every journey sound quality was better.
The K41 is the perfect device for my needs (roon core, already 2 4TB ssds nearly full, direct Ethernet output).
So I am looking forward to G5!
And during update time all Antipodes dealers have to provide music lovers with substitutes :wink:
Hi, I have the same problem. Did you manage to register? If so, please help.
Yes, we did.
If you are having troubles registering a device, please PM or email me the serial number and the model of the device
If you purchase a K50 now, will you be eligible for the Gen 5 upgrade when they’re released?
All devices listed are eligible
Hi, I tried to provide the last four digits of my K50 serial number and it says Antipodes can’t confirm the numbers I provided. What can I do?
