Hi. I am wondering if K-series devices (particularly K41) can benefit from being attached to an external Ground Block (in my case a Synergistic Research Ground Block) or if there are reasons not to do it…
Look up Grounding K50 for posts about this.
I have EX and it benefits from HD ground wire to Synergistic Research Active Ground Block SE. Grounding seems to be very much cumulative across a whole system rather than big impact on one device. But the sum of the accumulation can be significant.
Thanks for your answer and related post. Since in the K41 there is nor RCA I was thinking of using the USB. I am assuming that would work as well?
I suppose the USB port would be OK for a ground connection I have not tried USB for ground.
