I have a dx gen3 bought in 2017 and it is not upgraded.I wonder if it can be connected to a Linn Klimax DS via Ethernet cable.
Anyone can help me?
Thanks.
Anyone can help me?
Thanks.
Yes, should work fine. You can use Linn Kazoo or the Linn App to control it and the DX. I had a Linn KDSM and a DX. Good luck!!
By not upgraded, do you mean software wise? Current AMS version v3.13.
Let us know if we need to move you on software-wise
