How to play attached storage with Roon
New user here as I inherited an EX from a friend. Looks like there are files on the attached storage but Roon doesn’t seem to recognize them.
What do I need to do to play them ?
This player sounds real good with a Stealth T-select into a T+A Dac 200. Beats my previous Melco but the Melco’s strength is Ethernet output.
Russ
In Roon, check Settings > Library > Skipped files to see if Roon opted to skip them. If so a reason will be provided.
If you don’t see any skipped files, the issue may be with Roon not being able to see the attached storage. Not sure if I can help with that other than to suggest it would be best to copy these to local storage, if possible.
I am sorry I wasn’t clear. These are on the internal drive of the EX.
Are you using the Antipodes Audio Dashboard and have the EX set up using the Roon preset?
Or are you using another Roon Server on your network and are wanting to access the files on the Antipodes?
If using the Roon preset on the EX you need to ensure that you are actually logged into Roon on the EX.
