Tried searching on the forum / web with no luck.
Since I’m using my MSB Digital Director as player now, the connection is as follow:
Oladra G4 (squeeze/squeeze (audio output:none) → RJ45 → MSB DD (Renderer V2 which supports up to 4xDSD) → MSB DAC → Amp → Speaker
I disabled C3PO/enabled the 2 UPnP plugins/installed DSDplayer.
Under the player setting the DSD player shows the following status message
Did I miss anything here or it’s just the limitation of squeeze to play DSD via RJ45? My thought is that this playback method is somehow under uPnP so the cause might be the related to the plugin but I’m not so sure haha. I can always use USB but just want to explore other digital outputs.
Thanks in advance and wish all a very happy 2025!
