First the good news. I updated my K50 to the current model and am happy with the improvements. I understood I had to replace my older HQ player version with the new version and bought it and got the key to sign in — The problem is nothing happens when I go to play Hq player on Roon. Is there something I have not done either on Roon or on the Antipodes site to get the Hq player to work
Ensure you have Roon+HQPlayer Preset selected.
Click the Cog to go to HQPlayer Set-up, default password is admin/admin
In the HQPlayer set-up ensure you have the correct output selected, in my example below that is K50 Player Gustard, which is my USB DAC, the Antipodes USB is the internal connection to the re-clocker.
Also while here you should select your filters and output sampling rate, along with clicking Auto-Rate Family.
Inside Roon, go to Set-Up to enable HQPlayer output, click Add
Inside Roon, go to Settings and Audio, re-name your HQPlayer to what you want and select it
Play and check that you have HQPlayer output
Thanks. Reloaded the key and everything is working now —- Thanks Eli
