Hello,
I’m using Rockna Wavedream DAC and I wonder if K50 is compatible with i2s.
Thanks.
Hello,
Thanks.
Hi there, indeed, the Rockna uses LVDS on the I2S input, so connectivity is all good.
Thanks a lot. I’m looking forward to arriving my new K50.
We understand the DSD Pin-Out config for I2S on the Rockna is that of PS Audio, the K50 is set at PS Audio config at factory.
Thank you for the confirmation. I’m going to order the hdmi cable ~
