Dear colleagues,
I hope to find an answer in this forum. I am seeking advice on the settings for the Matrix X-Sabre 3 and the appropriate type of for the Antipodes P1+EX when synchronizing the clock from the EX. I am using an HDMI cable from Supra. Check all types in IIS-LVDS Port Definition menu, try to ON/OFF Jitter Eliminator.
In D/A working mode menu with Async everything sounds good, but in Sync mode, I hear noise when selecting different port definition types. Could the issue be with the cable, or have I selected the incorrect setting? For the P1, I chose the Gustard type.
My next step is to start using the Tubulus Concentus i2s cable that I have already ordered. I would appreciate any recommendations you may have.
Thank you!
