Was wondering if someone fitted some isolation feet to replace the stock one.
Thx
Roy
Thx
Roy
I used CMS center stage 2 1.0 under the K50 G3. Under the K50 G4 I am using CMS centerstage 2m 1.5. I prefer the sound with the footers.
Thanks. Anything that can replace the existing feet ? What kind of thread is used in the G3 ?
I use Alto Extremo Neoflex, size L. So I let the K50 float. Huge sound improvement.
