Yes, should have said, Paul Hynes SR7 Turbo, with Audio Sensibility DC cables for router and switches.
I could/should have known
except I do not understand what modem/router or separates you currently use?
I’d be interested in what is considered an audiophile router…Draytek is popular in the UK for reliability. I tried an Edgerouter, but I just couldn’t configure the damn thing. But as we are about to get fibre in our area, I am waiting to see what that implies…I think a modem and then the router?
You already tried more than I thought. They are not widely available as the audiophile switches are. Separating into a unique audio stream after the internet enters the home with no interference from other devices on the home network is what counts it seems. But as mentioned above the SOtM upgrade for a better router could be an idea?
Our hobby causes much shame at the best of times, and I think lawyers might get involved if I try this…
As long as you do not screw it direct in the wall. Would it evacuate micro-vibrations better than the Stillpoints, who knows?
I am a bit wary of the idealisation of Taiko, and the extraordinary praise lavished upon anything they do. The comments here regarding Antipodes are much more balanced, despite, I suspect, comparable levels of genius behind the products. Taiko are also rather late to network switch developments (and I still don’t understand why it is called a switch with one input, one output) and SOtM, amongst others, have been learning about network issues for quite a few years now. I trust my dealer has done some of the checking out of other products, and in our world of online influencers, I am relieved by that.
However, I will continue to tweak, and enjoy these occasional discoveries.
Great! I suggest you read about the Taiko Audio Extreme Switch development at WBF, in general it helped me to understand why routers and switches can (or could) sound better. Low noise levels , low power consumption and excellent EMI shielding all elevating sound quality was never in the design brief of common switches. Add to that the awareness at Taiko that home network can influence your analog playback chain and how to eliminate this.
In the end we all want the influence of networking on sound quality to be zero. Streamed files to sound as the best local files so we have access to everything at the same level of high sound quality; that’s clearly what Taiko in 2023 and onwards is moving towards to (without excluding others).
And thanks for the replies.
Taiko switch info:
https://www.monoandstereo.com/2023/01/new-taiko-audio-extreme-switch-and.html
