Good day,
I am experiencing issues with the K22 server disappearing from the Antipodes setup or myantipodes. When I try to approach directly on the IP address it also does not show up.
The K22 is linked directly from the K41 Direct Stream port. When I push the cable in just a bit more it comes back but after some time it disappears again.
I have a Synergistic Research Galileo Discovery Ethernet cable, which I now put in my Synergistic Research Ethernet switch directly where it seems to keep the connection.
The SR Ethernet connectors are standard size in my opinion. Any ideas on how I can fix this issue myself?
Does the issue happen on a normal ethernet cable?
