Hello everyone
If i am going to use only the usb output
Should i go with 21 or the k22 will give me better sound?
My dac is Ideon eos
On antipodes wab site it says that the usb is equivalent but my dealer says I will get a better sound from the k22
What do you think guys
If you plan to use only USB, which we believe is our best output on G4 music servers, then the K21 is the ideal choice; there is no reason to purchase the K22, spending money on outputs you may never use.
The K21 and K22 are identical except that the K22 has the re-clocker.
Hi Shay,
I’m using Antipodes K22 G4 with my IDEON Audio ION DAC and extremely pleased!
Had different streamer before, including Lumin U1, Auralic, Melco, but have to say (without getting paid!!) - impressed about K22 & ION synergy!
Also using the fantastic Ideon Audio USB Siren cable, very nice!
Using my K22 only as roon-bridge and was preferring it as I want S/PDIF, Toslink and USB. It is a pretty damn good match with Ideon and the best I’d in this chain so far. As someone saying it, also owning Grimm Audio MU2 in my other chain!
Rgds
Gerald
Thankyou for posting, we would also agree that Ideon make great DACs
