My antipodes K22 keeps disappearing from myantipodes.com
K41 is fine
Roon carries on working though
You may want to see if rebooting your network (switches and routers) helps.
it does but this keeps on happening but i guess it should not
did not happen before upgrade to AMS 5.0.1 via support session
Do you leave your DAC powered on all the time?
either powered on or in standby
was okay overnight if i left my dac powered on
but has disappeared when i switched the dac to standby
What happens if you use: Setup Your Antipodes - Antipodes Products On Your Network
What version of AMS is the K22 running?
Often times this can be router related, have you rebooted your network?
We also have a Beta Dshboard App for Windows: My Antipodes Dashboard - Free download and install on Windows | Microsoft Store
And for MAC: My Antipodes Dashboard App - App Store
Also My Antipodes Dashboard is available for Android and iOS
Setup your antipodes - shows both K22 and K41
AMS 5.0.1
I have not rebooted recently
Then there is no issue ![]()
