Hi all,
I have a K41 server and a K22 wich I use as endpoint.
In myantipodes.com I do not see the K22 as a Networkplayer but as a server. Is this correct? Does it make a difference?
Hi all,
No, thats expected and no issues.
Any reason you dont use the link from, the website?
If that is normal behavior then it is fine with me.
When I use the link from the website, he does not find any servers. myantipodes.com does
Can you please PM me your location, ISP, and external IP address found here⦠https://whatismyipaddress.com/
