Could you please confirm the specification for the 12v output on the K30, together with the size/polarity of the connector. Many thanks…
@MarkCole Is this one you could confirm for me? Many thanks
The centre is always positive, the plug size is 2.5mm
Thanks Mark, what’s the current rating?
The output is designed to run a S20.
Anything else there will suck current from the CPU
