Updated to 4.1 and now when I try for Squeeze with Roon Server I cannot access my Dave as an Output.
Have tried the usual reboots, etc to no avail.
Thoughts please? Thanks in advance.
Hi there, If you have the Solution Dashboard set, your Roon core should be accessible via your remote device, like wise your DAC sgould be set here.
Go to Settings/Set-Up in Roon, toggle “enable Squeezebox support” on and off
Bet you wished all support posts were this easy!!! Thanks Mark.
