Hi Everyone,
I just got my K50 and connected it with my DCS Rossini APXE DAC and Rossini Clock.
I am using AES and I am not sure whether its clocked or not…
Can someone please shed some light on this?
Hi Everyone,
The Word Clock Output on all Antipodes serves runs in multiples of 44.1 and 48khz.
Any device connected via Word Clock must be run in SLAVE mode.
From my understanding the golden rule with DCS is that the source must be slaved to DCS, this is not possible with any Antipodes products.
However if the DCS has a Reference input then in the Reference input setting it must be set to TTL.
The DCS is a grade 1 master clock, there is nothing to be gained in slaving it.
When connecting via AES the signal is reclocked in the Antipodes, then reclocked again in the DCS.
Thank you for the quick response, Mark.
The DCS is set to automatic. and there is no setting such a TTL that I am aware of.
I just want to make sure that I set everything up the best possible way.
