When I start Squeeze server and open the Web page. I get an interface with visual ‘tags’ (see pictures). Is there any way I can remove those?
Hi there, what browser are you using?
Works best on Chrome.
Please clear your browser cache and restart the browser.
Hi Mark, I tried both Chrome and Safari. Same problem on both browsers. Clearing cache and restarting does not change anything unfortunately
Make sure the Material plugin is checked in your list of plugins. Maybe unchecked it… save… then check it… save.
Hi @kennyb123 It was a bit challenging changing the setting through the cluttered interface, but finally it worked. Thanks a lot!
