Listen Later capability for Squeeze?
Based on the experience of others who have found Squeeze to sound superior to Roon, I have been experimenting with it in my system. I have found that it is significantly better sounding, however one of the features that I really miss from Roon is the ability to easily put an album on my Listen Later list. Is there something similar in Squeeze? I have looked through the plugins and native features, but nothing jumped out at me. Thanks.
True, there is no “Listen Later” there are a couple of ways you could approach it:
1/ Save to a Playlist you have created called “Listen Later”
2/ Use the “Add to Favorites” as a listen later list
Thanks Mark, I will use one of those options.
