Lost Settings on K30
Today my K30 dashboard lost baccess to servers and no options for players. It’s still playing using the last set up Roon/Squeeze but I can’t change anything.
Dashboard pic attached.
Many Thanks
PS Tried rebooting but no change
You’ll need to setup a remote support session.
Click on Assistance in Circle.
OK, thanks, thought it might be the case, second time in 3 months :frowning:
I believe you should get a fix that will allow you to correct that problem yourself should it happen again.
That’d be great… I need to borrow a laptop and then I’ll set up the support session. Thanks
Thanks to Prince, all sorted now.
