When playing squeeze via Material player, sometimes songs are stuck at the end. The next song will not start unless I manually press forward in Material. Anyone else recognizes this? What should be done about it?
Hi there, can you advise the source material and location of the files this happens on please.
Hi Mark, I use Qobuz as a major source. I actually don’t play local files but will try that soon to check if this problem also appears in this setup.
Hmm may be a Qobuz thing, let me know, have no other reports of issues,
I made some screenrecordings but can’t share them. Only still pictures. Can I email?
sure
support@antipodes.audio
