Hello, brand new owner and member to the Antipodes community here. I’m coming from an Innuos Zenith Mk3 and couldn’t find any other posts here going into the specifics of moving from a previous Roon setup. I set up an empty core on my new K21 but quickly realized that I wasn’t going to have any of my listening history that way. So I tried restoring from a backup from my Zenith. This seemed to do the trick but I had a bit of strange behavior with my library that eventually required me to run some of the library cleanup options and rebuild my local library from scratch. it also changed the name of my core back to what it was instead of the host name for my K21.
My question is, is this a valid way to do things or should I have just started from scratch? I’m just not sure how sandboxed Roon is with the Antipodes and whether it is worthwhile going through all this trouble just to get my history if it introduces a lot of cruft into what should be a clean database. Also, is there any easy way to reset Roon through the Antipodes interface to an empty database if I want to just start from scratch again?
