I have a 2tb ssd in my EX running 3.1. Can I simply power down the EX, remove drive and then place it in new K series without losing data?
@Progisus
The theory is this should be seamless, using File Manager on the K30. Just add it in.
Always, always recommend a back-up, however, just to be sure
Is this the same case with all Antipodes servers? IE: moving from an Antipodes CORE to a CX?
@desbiss
Assuming the drive has no OS on it, yes,
No OS, just music files. Thanks Mark!
