Myantipodes Issues
We are experiencing an issue with myantipodes currently.
Please use myantipodes.com, and launch the Solution Dashboard from the player.
Using CX (192.168.1.89). Can open Solution dashboard and Player dashboard, but when I try to open Server dashboard it times out with:
It appears to be using an IP Address one slot lower than the actual one, i.e. 88 instead of 89.
Is this part of the issues you refer to?
I should add that this is the actual url that has failed:
When I change the erroneous 88 back to 89 the Server dashboard is correctly displayed.
All fixed now. It was a database problem that has now been fixed and should not happen again. It was a strange conflict with the migration to the new website, but now permanently fixed.
