NAA HQPlayer setup on K50
Hi antipodes community,
I would like to run my K50 as a Roon server and NAA HQPlayer with the HQPlayer5Desktop app running on my MacBook Pro M1 Max. However, I’m unable to make it work. If possible, could you please share the required settings to make it work?
Below are my current software and settings information:
Software:
  • K50 vesion AMSv5.0.1
  • HQPlayer 5 Desktop version 5.17.1 (registered version)
K50 Solution Dashboard settings:
Server App → Roon
Player App → HQPlayer with Roon Server
Player App → HQPlayer settings:
Network Audio backend (at the bottom) → Device → K50player: Kii Control: USB Audio selected
HQPlayer 5 Desktop settings:
network control turned on
HQPlayer 5 Desktop Preferences settings - under - Outputs:
Backend → NetworkAudioAdapter
Device → only the orendu-021031: Hugo2: USB Audio is popping up, but not the K50player: Kii Control: USB Audio selected previously in the K50 Solution Dashboard Player App → HQPlayer settings.
Even if I switch the Sonore opticalRendu back to RoonReady, the K50player: Kii Control: USB Audio will not appear in the HQPlayer 5 Desktop → Outputs → Device settings.
The NAA HQPlayer on the Sonore opticalRendu through Roon and HQPlayer 5 Desktop on the MacBook Pro M1 Max is working:
The HQPlayer Embedded (trial version) is also working, but I would like to run the heavy processing from the Mac.
Any help to resolve the NAA HQPlayer setup issue would be much appreciated.
Cheers and thank you from Down Under,
Andreas
If HQPlayer server on your K50 is configured to output to the NAA on the K50, HQPlayer desktop can’t see the NAA as available for its use. Shut down HQPlayer server on the K50 and it should work.
Hi Ken,
Thank you for your reply! and it It is working now with the following settings:
Server App → Roon ON → HQPlayer OFF
HQPlayer → click refresh icon
Device → K50player: Kii Control: USB Audio popped up
and all is working with Roon and the NAA HQPlayer through the HQPlayer 5 Desktop on the Mac…
Thank you again!!!
Cheers,
Andreas
