I just came across a link to this while browsing WBF: Connector Weight Support - Audio Bastion
This looks like it will offer a good way of relieving strain on USB cables, which can be loosely gripped on some of our servers.
My USB cable is on the heavy side so I’m inclined to try one.
7Ryder
2
Good find. This will also help if you have a big-ass cable attached to light weight electronics and will keep them from tipping upwards in the front.
A friend had shared this link in response to mine. Scroll down to You May Also Like to see many other options.
