Network Switch indicator lights
A ‘for my information’ question - everything working Ok…
Ive just been rewiring/rerouting all my ethernet cables on my switch.
For almost all connections the ‘flashing’ signal lights on the switch indicate that the connections are made and working.
On the ethernet cable at the switch end from my S30 though, no lights are showing.
On the S30 lights are showing
System is working fine so not worried, but would like to know why this is different to other connections.
(maybe its just that Antipodes doesn’t spend its life polling every other unit on the network lol)
