Hi all,
Everything was working fine with My Antipodes CX(server) & EX(Player). Then I just purchased a new DAC (Soulnote D-1N) I was happy to finally bypass my Antipodes S-20, due to the fact my Bel Canto dac didn’t have USB. I put in the new Dac. On the EX dashboard no USB on the audio ouput selection appeared. I tried bringing back the S20 and tried AES into my new DAc, no audio still. Then I thought I should regroup and put back the old Bel Canto Dac. Now again no audio… I can see the music playing in my squeezebox gui. Showing the CX as the server and EX as the player. I can open the EX dashboard no problem, therefore the network connection seems fine. I’m totally scratching my head.
Any other ideas I should check for this troubleshooting ?? I’m stumped and bummed I can’t hear any music, let alone my new DAC. Seems everything is working except the audio getting out of my EX
Cheers
Did you try powering up the EX? I expierenced this issue long time ago and had to shutt off power (first with button, if orange than switch off at the back). This made sure the EX did a so called ‘handover’ to the usb input on my dac.
PROBLEM SOLVED !!
Yes I always start trouble shooting with powering cycle.
Being that this is a new DAC and a different setup from my previous DAC which did not have a USB input. I was previously using an Antipodes S20 to take the usb signal from the EX and send it to my bel canto via AES/EBU. In that setup I was using USB Audio 2.0 5V off. with this new DAC I needed to use USB audio 2.0 5V On. I did try both slots , but the Dac needed to power off/on to recognize the source.
I’m posting this solution in case someone else might have the same panic I did. I was prepared to call the dealer and tell him the DAC is broken.
Cheers
Good to hear the problem is solved. And as often, the details count. Happy listening. And excellent trouble shooting!
