No temp display
running on - AMSv5.0.1
Perhaps more an irk than a problem per se, but dashboard core temp field displays °C with no preceding value for both the server and the player. Anyone else have same experience and if so, assuming it wasn’t/hasn’t simply been ignored, what’s ‘the fix’?
Cheers.
Which server?
Has it ever displayed the temps?
Hi.
DX Gen 3 upgrade - comes up as D1 on dashboard - as server, and EX as player.
And no. The units had the software update and never displayed temp thereafter
It is a known issue to Antipodes at least for me for my cx server and not ex player with ams5.0.1 upgrade from ams4.0 that showed temp for both cx and ex and expect fix only in next release as advised by Antipodes. Cheers.
Hi Richard
You saying temp shows on your ex player, but not on cx server? Like for you, core temp for server and player displayed prior to upgrade. Like I say, not a problem per se. It’s a tad irksome and I’m more just curious if “just me”…your reply says it’s not just me :wink:
Oops … it is ex reader not showing temp and not cx server as shown … with apology. Yes, both showing temp with ams4.0 and Antipodes informed me on this during support session for upgrade to ams5.0.1. Cheers.
