Oladra feet / isolators recommendations?
wondering how good the oladra feet are - due to temp accommodation my oladra is sitting on the floor and i dont have any height to put a rack in so wondering whether i should invest in some isolators or an isolation base like these Nimbus System | Chassis Noise Reduction | HRS - or are the oladra feet already doing a good job?
That’s my understanding. I’,m assuming that when my updated K50 comes back, the team at Antipodes would have fitted the best feet they believe are possible and I have no reason to doubt them.
Stick with what Antipodes have fitted.
The criteria by which ā€œbestā€ is determined may not be the same for everyone. Most determinations of ā€œbestā€ are bound by some fixed constraints - like around cost or practical considerations. I can’t imagine that Antipodes would have gone as far, for example, as including feet that would have caused them to have to raise the retail price by a considerable amount. That leaves open the possibility that other highly regarded solutions, like those from HRS or Stillpoints, might still offer better performance. I think we will have to wait to hear from what users report about these.
The surface on which we place these footers also has a say in which footer might work ā€œbestā€. Thus, we might expect that circumstances where the Oladra feet prove to be great on some surfaces while another product might work better on others. We’ll just have to see.
Not a good idea to have it sitting directly on the floor - especially if it’s carpeted. A bamboo cutting board would be a good low-cost solution for it to sit on. I do this now with one of my power conditioners.
Excellent suggestions. I have also used some granite pieces I acquired from countertop installers that were squared that I used for some amps. A place like Home Depot may have some of these as well. I then added some of the Herbie’s Tenderfeet under the amps, which would not be needed with the Antipodes feet supplied with the upgrades. I also used some Herbie’s Audio Labs Superior Decoupling Spikes under the granite pieces to the carpet.
The goal should be to select a material that dissipates energy without converting it into a single resonant frequency. Granite pieces will ring at a particular frequency.
Bamboo is actually nearly perfect for audio, as Roy Gregory points out so well in the following. This is what lead me to selecting a Quadraspire rack with bamboo shelves. I also stock-piled these Aptitlig cutting boards at one time.
Here’s a quote:
ā€œWhat makes bamboo so effective in the audio world is its structure and the process that allows us to turn what is basically a massive fibrous grass into a flat board. The bamboo itself is formed from long bundles of cellulose fibers, bound together by lignin, a natural thermoplastic resin. The closer to the surface you get, the greater the density of those fibers. The result is not unlike natural carbon fiber, but considerably heavier. Take that structure and cut it into strips that can then be stacked face to face to create a single flat board and you have a random, composite, variable-density material – which is just about ideal for dissipating mechanical energy effectively without converting it into a single, dominant resonant frequency the way that glass or MDF does. Great in theory – how does it work in practice? Better than you are going to believe – which is exactly why Atacama and Quadraspire have made it central to their product lines.ā€
The Best Things in Life Are (Almost) Free: IKEA’s Aptitlig Chopping Boards - The Audio Beat - www.TheAudioBeat.com
Like an itch that was impossible not to scratch, I eventually put some Center Stage 2M feet under the Oldara, and there was a marginal improvement. The Oladra sits on an Audiophile Base rack, for now. When I can shift things around, a Quadraspire Reference rack, with its bamboo shelves, as @kennyb123 suggests, might be better still. Whether the 2M feet then still offer some improvement, I don’t know.
But I would seriously question value for money with such a venture, and imagine a focus on mains quality, cables and, with G4, grounding may give much more of a return. But when seeking perfection, you sometimes just have to bite the bullet and do stupid things.
This mirrors my observations when placing Stillpoints under my K30. The improvement didn’t justify the price as well as I had come to expect from Stillpoints. Fortunately I had gotten a good deal on a used set.
I do make purchases with the long term view that future upgrades may make some choices make even more sense down the road. I will revisit the Stillpoints when I have the new feet to compare them to. My system ā€˜s transparency has increased quite a bit since the last comparison so I think there’s a chance the Stillpoints might better justify their cost.
I think you have them already, there is nothing to lose in trying them again. But it is defintely a ā€˜try before you buy’ situation if you don’t have them already.
Worth noting that in the Stereophile review JVS got some improvement from trying some other feet (can’t remember which ones, now), and I imagine his system is pretty transparent.
Christiaan Punter does a very thorough job of evaluating some of the HRS products. He mentions how the Oladra responds to their footers when used with an HRS rack:
On the last page, Christiaan talks about the HRS damping plates. I have a few of these and like how well they work in conjunction with Stillpoints underneath the component. Downside is that the material can leave a mark. I had used a damping plate on top of an Innuos Zenith Mk3 and struggled to get the mark removed until my dealer suggested something that did the trick.
This same dealer also carries Artesania so I might inquire about their damper.
Last night I finally tried to sort out how Stillpoints Ultra SS compare to the G4 footers on the K50 G4. First time I had ever had the K50 sitting on its own feet as the Stillpoints have been in use under whichever music server I’ve used for a long time. My rack is a Quadraspire SVT with bamboo shelves.
I will first off admit that I didn’t put a lot of effort into the comparison. When I pulled the Stillpoints out, the difference was subtle and I tend to not have a lot of patience when differences are small.
It took a few tries to get to a demo track that would allow me to asses the difference. I ultimately landed on Some People’s Lives from Janis Ian’s spectacular Breaking Silence album. This track features only Janis and her piano. Both sound beautiful.
Pulling the Stillpoints threw things very slightly out of focus. Nothing offensive about it so I think one could easily be satisfied with the G4 feet. Tossing the Stillpoints back in dialed the focus back in. It was subtle but in better systems this might be viewed as worthwhile as it increased coherence especially to the piano as the strikes of the hammer became slightly more believable. Tone density improved by a smidgen too.
Next up, I placed an HRS damping plate on top of the K50. This was even more subtle than the Stillpoints but after a number of swaps it did seem as though it brought improvements of the same kind as the Stillpoints but at a lower magnitude. Not worth paying full price but some might appreciate what this does. One thing I think I noticed was that the lower frequency notes from her piano seemed to lose a little extra oomph - possibly a resonance reduction. But I wouldn’t bet money on this as it was extremely subtle.
If you just need smth under your AMS , I suggest trying Finite Elemente CarbonFibre platform. Swapping it’s stock feet to Cerabase Compact will yield even better results - fuller and more articulate sound, lower bass extension and cleaner highs/mids. Addding another set of Compact feet btw the Antipodes and the platform will bring a big smile on your face. Definitely give it a try if you have a Finite Elemente dealer nearby willing to loan this to you for auditioning .
A friend of mine, owner of an Oladra G4, has placed three ā€œFinite Elements Cerabase Compactā€ under the device and is thrilled! A question: are the feet of the Oladra G4 removable? Are they screwed? If so, what thread do they use (the Cerabase Compact come with M6 and M8)?
The footers on an OLADRA 1 are not removable
Thanks Mark, best for me… not being able to fix them, it will be easier to borrow them for a test from me too!! :innocent: :innocent:
At one time, I owned two sets of one of their more affordable footer, the Ceraball. Similar design, except a single ball bearing. I found them to be a good value and also very neutral sounding. The design is relatively simple, which reduces manufacturing complexity and that helps to make them a good value. It’s important with these to follow their optimum component weight specification. You should definitely try them if you can.
Are the K50 G4 feet removable Mark?
I’ve been using Stack Audio products under other stuff to great advantage
The Stack Audio platform works well under my turntable and I’ve tried under my CD player too
No, none of the footers on G4 and below were made to be interchangeable.
