Oladra G4 grounding options
What grounding you guys use with Oladra G4? Any recommendations?
Puritan Audio Ground Master works for me.
Quietens down the background
I suggest if you have shelled out for an Oladra, your whole system deserves comprehensive grounding with grounding sysyem of similar calibre. There can be a significant difference between simple grounding cables and devices and higher grade products.
I use Synergistic Research Active Ground Block SE with HD and HDSX ground cables to ground all components and cables that can be grounded.
My router and ONT, and related cables are grounded to Synergistic Research passive ground block. There is a vast difference between the actuve and passive models, and these are not top of the line in this brand.
Grounding one component is barely the tip of the iceburg of potential.
I never used any grounding with my system. I’m using Ansuz active cables, power conditioner and switch and my dealer advised that I don’t need additional grounding devices.
I only have three components now where Oladra and Diablo 333 have grounding posts. Interesting to learn that you grounded your router and ONT as well. How do you ground these devices or their DC cables?
Puritan Ground Master with external grounding rods in my garden
Preferred mine to Synergistic, better performance.
Computer Audio Designs GC 3.1 for signal grounding and GC 3.0 for chassis grounding.
Ah, that explains why no grounding.
My router has a ground terminal, with my previous router I openned it up and found a suitable screw to use.
The ONT is not as easy, it belongs to the provider and is a sealed unit without ground. So I use a ground cable with a rj45.
Those are connected to the Synergistic Research passive ground block, which is further ā€˜conditioned’ by sitting on a Synergistic Research Tranquility Pod, and the ground block is connected to the earth of an ifi AC purifier which is really just a makeshift termination for now.
On my wish list is time to explore how to somehow connect my 2 ground blocks direct to a dedicated well installed earth rod, perhaps via something like the puritan. There are several other things higher up the wish list. Currently finishing developing a hybrid triple cascade type smps/linear psu for the ONT and router.
Thanks for the explanation. I’ll check whether my MikroTik router has any grounding options. My ONT is a TP-Link, so it’s similar to yours.
I use iFi PSUs for both devices.
Interesting. Do you mean a DIY PSU, or is it something of the shelf?
My ONT is Alcatel/nokiafor GPON, My router is Mikrotik CRS 305.
It will be DIY using off the shelf components.
Is that because you couldn’t find a suitable power supply on the market, or are you already going down the DIY route?
My experience has been that LPSs on network switches tend to soften the attack and reduce perceived transient impact. SMPSs, on the other hand, can sound a bit harder and more ā€œdigitalā€.
For me, your approach makes sense.
Do you have any recommendations for a router power supply that can be purchased off the shelf?
I was on the DIY route … I was intending to use batteries to completely isolate from AC and possible noise transmission via AC between network devices. But I changed tack for ONT and router because they’re always on so couldn’t be bothered working out how to manage charging and disconnecting the charger for ā€˜hifi time’. And thought … if Antipodes use smps, then surely I can work out something smps for the ont and router that is lower cost than what’s available.
I’m learning alot. Both smps and linear regulators have their strengths, and its likely they can be complimentry when I work out filtering. Filtering is Antipodes secret sauce between the off the shelf smps and the ā€˜engines’.
Their intermediate stage seems a custom buck convertor and cascade filter network. I cant find any like it off the shelf. If I’m right it is like a reclocker/upsampler. It increases the switching to a frequency that is more efficient to filter. Sound familiar?
But there are other ways to filter, there are lower noise smps’s and my ont and small router are less demanding than a server cpu in terms of current.
Uptone JS4 is triple cascade hybrid … transformer > high frequency switching > heavy lifting liner pre regulator > final LT3045 linear regulators. There is filtering after each stage.
I havent experiemented with off the shelf complete power supplies for the ont and router. So im unable to make a recommendation.
Interesting. Are your analogue and digital audio devices already running on battery power?
Good power supplies like the JS-4 are rather expensive, and I’m still not convinced they’re worth the investment for network devices.
My MikroTik requires 24 V (it’s currently powered by an iFi iPower Elite), which also limits the range of suitable options.
I see that the Ferrum Hypsos is a hybrid power supply with two outputs and up to 30 V available, so it could potentially power both my ONT and MikroTik.
Only the last hop to the streamer, it is Mikrotik mAP lite [mini wap router], runs off usb powerbank which was better than LPS + $1k power cord via power conditioner … last time I checked.
There’s so many that accept 12. Maybe you got the RB401, RB500 or L009.
The Hypsos is similar expense to JS 4. Its odd that its hybrid but still has a big transformer, which is a barrier to AC noise but also resistance to current flow … which might be why the Hypsos has 4 very large capacitors. Maybe its smps stage is aimed to shift the noise into higher, easier to filter frequencies. https://www.alpha-audio.net/review/review-ferrum-hypsos-power-supply/
My guess is … using linear regulators to burn off only the last couple volts to achieve lower noise and ripple is optimal use of linear LDOs. Everything before that should reduce the voltage and noise as efficienty as feasible to hand over to that final stage.
For example, LT 3045s only need to burn off 1v to achieve pretty close to highest performance … and that is a tiny amount of heat. Any more than 1v generates more heat for tiny if any benefit, any less and performance declines.
