The network speed of my Oladra is reported as 1G but i thought the specification said it is 2.5G is threre any reason for that? thanks
Your remark surprised me. I was even more surprised to see the spec indicate “2.5 Gigabit Ethernet”.
Are you connecting to correct port to a 2.5 G switch?
I connected via oladra’s ethernet port to my 2.5G switch. So it should work.
The 2.5 G spec is obtained from the Antipodes website.
Is you internet service 2.5G?
