Oladra No Connecting to Network and no Green Lights
I’m having ongoing issues with my Oladra…
Can’t connect to my network
And
No green light on front panel
Please note I’ve actioned recommended fix on the Antipodes Website with no success…,
Are you sure about power supply ?
Press the power button on the front and hold it for a few seconds.
Are you using the original power cord?
I had some problems replacing it with the Valhalla one. It didn’t fit properly by a millimeter, but it was fixed.
Ciao
Nicola
Yes, not a power cord issue. Red flashing light becomes solid red…
@SAMMAN Book a support session:
