I’m curious about the use of the USB A and HDMI in the Ethernet RJ45 slot on the back panel of the Oladra.
Wild guess: The ports labeled servicing give the Antipodes technician the ability to connect a keyboard and monitor so they can see what’s going on when doing diagnostics.
The two USB ports under the Ethernet ports are for connecting either external drives or an optical drive.
Correct, HDMI is for monitor connection for service
